Continuum ODBC Data Source does not appear in Windows ODBC Data Source Administrator
  • Continuum ODBC Data Source does not appear in Windows ODBC Data Source Administrator
  • AbeMeran
    AbeMeran
‎2018-09-11 05:29 AM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-13 07:04 AM
Continuum ODBC Data Source does not appear in Windows ODBC Data Source Administrator. Continuum is operating normally in spite of this.
Andover Continuum
  • CyberStation
  • Windows 7
Multiple possible causes
  1. Windows issue
  2. Known Continuum issue in 1.94 running in 64 bit machine.
  1. See Microsoft solution: System DSN Entries Do Not Appear in ODBC Data Source Administrator (odbcad32.exe)
  2. Continuum ODBC System DSN is not created on x64 Bit systems
    A workaround is to run c:\Windows\SysWOW64\odbcad32.exe and the Continuum ODBC is available.
  • 12068
