Continuum FIPS-PIV reader output formats supported in Continuum.
  • Continuum FIPS-PIV reader output formats supported in Continuum.
  • AbeMeran
    AbeMeran
‎2018-09-06 12:15 PM
What are the FIPS-PIV reader outputs supported by Continuum?
CyberStation
CX9680
ACX5720
ACX5740
Questions on configuring a FIPS-PIV reader to work with Continuum.
Continuum FIPS-PIV enabled controllers (9680, 5720 and 5740) require a minimum 75 bit Wiegand output from a FIPS-PIV readers.
Typically card readers can be configured to select the FIPS PIV output format sent by the reader.
The following output formats are supported:
  • Built-in Formats:
    • Wiegand 75-bit
      • Agency + System + Credential + Expiration Date
    • Wiegand 200-bit
      • 200-bit FASC-N (No Expiration Date)
All other formats are considered FIPS-PIV Custom Card format and must be specified by the user via the FIPS-PIV Custom Format System variable.
  • Custom Format Examples:
    • 200-bit FASC-N with embedded expiration date
    • 245-bit FASC-N with appended expiration date
    • Custom Medium-Assurance Format Examples:
    • 200-bit FASC-N with embedded HMAC
    • 107-bit: 75-bit PIV + 32-bit HMAC
    • 32-bit HMAC + 200-bit FASC-N
  • 8115
