Connection kits for Venta series valves V241/V341
  • Connection kits for Venta series valves V241/V341
  • SESA150559
    SESA150559
‎2018-09-06 10:26 AM
If soldering or welding is required for connecting the valves, different kits are available.
Venta
V241
V241
Different applications requires different ways of connecting the valve to the pipe work.
There are 3 different kits available: for welding, soldering and for internal threads. All details and part numbers are available in the data sheets. Please note that one (1) kit is required for each port.
  • Field Devices
  • 13157
