Unable to Connect to a Link or Site in I/NET Seven
  • Unable to Connect to a Link or Site in I/NET Seven
  • RobertAndriolo
    RobertAndriolo
  • sesa139513
    sesa139513
  • SESA128071
    SESA128071
‎2018-09-06 03:08 PM
Last Updated: Picard RobertAndriolo Picard ‎2025-10-15 05:56 PM
Unable to connect to a Link or Site in I/NET Seven.
TAC I/NET
I/NET Seven
The user interface requires specific steps to initiate a connection, which may not be immediately intuitive without prior experience.
To connect to a device or site in I/NET Seven, follow these steps:
  1. From the main menu, select Connect. A summary list of available link devices or sites will be displayed.
    Note: A dash (-) next to a device name indicates it is currently unavailable for communication. An asterisk (*) indicates that the controller name or type has changed.
  2. Highlight the desired link device or site from the list.
  3. Select OK to initiate the connection. Once connected, the status bar at the bottom of the screen will display the connected levels.
Warning
Important: Ensure that the selected device or site is available and correctly configured before attempting to connect. Misconfigured or unavailable devices may result in failed connections or unexpected behavior.
  • TAC INET
Tags (2)
  • 1875
  • RobertAndriolo25
