Connecting an I/NET SubLAN to a Security Expert SP-C
  • Connecting an I/NET SubLAN to a Security Expert SP-C
  • RandyDavis
    RandyDavis
  • RichardWa
    RichardWa
Ensign RichardWa Ensign
‎2020-03-04 05:41 AM
on ‎2020-03-04 05:41 AM
  • You are transitioning an I/NET security system to Security Expert
  • The I/NET subLAN must be moved from a 779x controller over to an SP-C
Security Expert, TAC INET
  • I/NET Controller (779x)
  • Security Expert Controller (SP-C)
As you transition an I/NET system to Security Expert, you will reach a point where you are ready to start moving your I/NET subLANs over to SP-Cs.
Use the following instructions to connect an I/NET subLAN cable to a Security Expert SP-C.
  1. At the I/NET 779x controller, disconnect the subLAN cable.
  2. At an SP-C, connect the subLAN cable as follows:
    1. Attach the positive (+) wire to Reader Port 1 pin "D0".
    2. Attach the negative (-) wire to Reader Port 1 pin "D1".
  1. If you wish to establish a closed-loop subLAN configuration, connect the other end of the subLAN wires to SP-C Reader Port 2 in exactly that same manner as you did at Reader Port 1.
Labels (2)
  • EcoStruxure Security Expert
  • TAC INET
Tags (2)
  • RichardWatson20
  • sublan
100% helpful (1/1)
