Connecting a SpaceLogic Controller via MSTP
  • Connecting a SpaceLogic Controller via MSTP
  • GavinHe
    GavinHe
Sisko GavinHe Sisko
‎2022-12-08 05:25 PM
How to connect a SpaceLogic IP Controller via MSTP
  • Workstation
  • Automation Server (ASP/ASB)
  • Space Logic IP Controller
  • RS-485 Adapter
Only certain SpaceLogic IP Controller models and versions support the new BACnet MSTP Adaptor and details are required on how to configure these controllers for BACnet MSTP.
The following video will illustrate how to:
  • Configure ASP/ASB for BACnet MSTP Communication.
  • Configure a SpaceLogic IP Controller as a BACnet MSTP device.
  • Discover the SpaceLogic IP Controller on the BACnet MSTP network.
Things you need:
  • Software
    • EcoStruxure Building Operation Workstation 2022
    • Building Commission Application (available from Google Play, Apple Store, or Microsoft Store)
  • Hardware
    • ASP/ASB version 4.0 or higher
    • RP controller (hardware version 10 )
    • RS-485 Adaptor (Isolating or Non-Isolating)
    • RJ45 UTP Straight Through Cable (12"/300mm or less)
    • Note: - if the RP controller does not show MSTP settings check the Space Logic IP controller firmware release notes and install firmware corresponding to the EBO version.  For example firmware versions 3 and below do not have settings for MSTP configuration.
  • Before attempting to install a SpaceLogic controller on MSTP consult the following:
    • Isolated RS-485 Adapter and Non-isolated RS-485 Adapter for SpaceLogic IP controller types supporting the RS-485 MSTP adapter
    • RP-C BACnet MS/TP Support for RP models supporting BACnet MS/TP
    • Installing an RS-485 Adapter for information on installing the BACnet MSTP adapter
    • Connecting an Isolated RS-485 Adapter and Connecting a Non-isolated RS-485 Adapter for port usage and CAT 5 UTP connection cable
    • Allocating Flexible Ports for additional considerations on port usage
    • Enabling the BACnet/IP Controller to Communicate on an MS/TP Network
Please see the video below:
Tags (2)
  • GavinHeward22
  • GavinHeward25
100% helpful (4/4)
