Configuring accupancy point in a schedule wont work.
  • Configuring accupancy point in a schedule wont work.
‎2018-09-06 01:42 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:36 AM
Create a schedule and attach a numeric to the occupancy point. Receiving error:
"Cannot resolve object: in Object Property List. Please save BACnet device to database or make sure the object still exists."
Click OK. Schedule opens up, but the occupancy point is empty under the configuration. However, the occupancy point that was attached is being controlled by the schedule.
CyberStation v1.74 SP2, 1.74SP2, 1.74
Received error when editing schedule.
For CyberStation v1.74 SP2, 1.74SP2, 1.74
Download Hotfix: CyberStation v1.74 TPA-BOST-08-0005.00 Hotfix
For Cyberstation Above 1.74
Make sure there is no object created in the controller using a name that is the same as the name of the Network under which the controller reside.
For example:
If you have a controller - Root\BOC\MainCX which contains a controller user object named BOC you will see the schedule issue.
  • 5612
