Configure a digital value to show as ON/OFF instead of 1/0 in a Xenta 5/7/9xx Value Page
  • Configure a digital value to show as ON/OFF instead of 1/0 in a Xenta 5/7/9xx Value Page
  • sesa150555
    sesa150555
‎2018-09-06 03:00 PM
  • Xenta Server
  • Xenta 511, 527, 701, 711, 721, 731, 913
  • Value Page
  • XBuilder
XBuilder Values Pages will read and display raw data from a variety of sources. It can be formatted in a graphics page or a third party interface to be displayed in any desired format, however, a Values Page is a simple drag-and-drop configuration. To alter the display, values must be routed through Signal objects in XBuilder.
Use the Enumeration Function. To create an enumeration that shows ON/OFF:
  1. On the Tools menu, click Enumerations.
  2. Under Enumerations, click New.
  3. Type the name (ON_OFF) and then press ENTER.
  4. Under Definitions, click New.
  5. For the value 0, ‘OFF’ then press ENTER.
  6. Under Definitions, click New.
  7. For the value 1, type ‘ON’ and then press ENTER.
  8. Click OK.
To use the enumeration:
  1. Create a signal in the System Pane for the point.
  2. Select the signal and find the property 'Enumeration'
  3. Click on the dropdown list and select ‘ON_OFF’.
  • 2514
