Clicking on TimeSchedule in Xenta Server gives this security warning, Java has discovered application components that could indicate a security concern.
  • Clicking on TimeSchedule in Xenta Server gives this security warning, Java has discovered application components that could i...
  • Benji
    Benji
  • sesa150555
    sesa150555
‎2018-09-07 04:27 AM
  • Clicking on Time Schedule in Xenta Server, gives this security warning
    Block potentially unsafe components from being run? (recommended)
  • After clicking "No" it works to browse different Time Schedules without any problem.
  • After logging out and in again you get the warning again
TAC Xenta 5xx/7xx/9xx
Java 1.6.-19 or later
This is not the recommended Java version for this Xenta server version.
Change the mixed code settings in the Java control panel. For information on how to do this go to: http://www.java.com/en/download/help/error_mixedcode.xml
OR
  1. Uninstall Java 1.6.-20 (or later)
  2. Install Java 1.6.-17
  • 4298
This is a heading
