Checking COM port settings in SIGNAL.
  • Checking COM port settings in SIGNAL.
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-11 03:52 AM
SIGNAL (all versions)
Troubleshooting communications
There are two locations to check COM port settings:  the main SIGNAL desktop and in Project Manager.
The setting must be an exact match in both locations.  The example below is for a Direct Connection to a GCM (Network 8000)
Main SIGNAL desktop
Click on the Utilities pull-down menu and select Configure Communications.
Highlight the computer COM port number to be used and then click the Configure button.
The following screen shows the required settings:
Project Manager
From the main SIGNAL desktop, click on Project Manager.
Double-click the Gateway Record and then the Communication button.
Ensure the settings are as illustrated below:
  • TAC IA Series
  • 13219
