Changing the Home Graphic in Workstation / Webstation.
  • Changing the Home Graphic in Workstation / Webstation.
  • Sacco
    Sacco
‎2018-09-06 12:52 PM
Customize the default graphic that opens after login.
  • Vista Workstation
  • Vista Webstation
Vista defaults to a generic view which can be customized.
The Home Graphic can be changed in any user profile, including the default Vista $UserProfile.  A user profile can be used by several users.
To create a User Profile
  1. In the folders pane, right-click the root object.
  2. Point to New, point to Object, and then click User Profile.
  3. Type the name of the object.
Browse the Home Graphic in the new User Profile and update each User properties to use the correct User Profile.
  • 6986
