Changing from Analog dial-up communication to VoIP (Voice over Internet Protocol)
  • Changing from Analog dial-up communication to VoIP (Voice over Internet Protocol)
  • sesa139513
    sesa139513
‎2018-09-06 02:27 PM
An upgrade site that has gone from a 7798b with dialup capability attached via modem to see the I/NET Seven C-Lan network has gone to VoIP phone communication. This changes the dialup communication. How to make this communication work?
I/NET Seven communicating with remote dial-up to a 7798b control board using USRobotics modem and analog phone line
Changing company structure to Voice over Internet Protocol (VoIP) rather than analog dial-up communications
  1. The Xenta 527 web based router will need to be in place to replace the dialup connection.
  2. Add a CLX card to the 7798b so it will work communicating to the 527 web based router (Note: the 7798C has this capability soldered onto the board and is not necessary).
  3. XBuilder will be required to set up graphic pages and email alerting if outbound communication from the network is needed.
  • TAC INET
  • 3928
