Changing attribute names for display in the Personnel Manager
  • Changing attribute names for display in the Personnel Manager
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:00 PM
Can I change the display of an attribute using the old Personnel Editor or in the Personnel template editor
Continuum Cyberstation
Change the display of a personnel attribute.
The old personnel editor or the personnel template editor there is no way to change the attribute name. In the new Personnel Manager you can change the display of an attribute name.
Example:  Changing attribute Info1 to BuildingNumber
  1. Open up a personnel record
  2. Select configure and select customize attributes
  3. Select the display name for the attribute to be changed
  4. Change the display name and select Ok.
  • 4834
