Change the default XBuilder project location
  • Change the default XBuilder project location
  • Benji
    Benji
‎2018-09-06 02:41 PM
How to change the default XBuilder project location.
XBuilder
The default XBuilder project location is in the hidden Application Data folder. Some would prefer to have this default to their usual projects folder on the hard drive.
  1. Go to Start > Run > and type 'regedit'
  2. Go to HKEY_CURRENT_USER > Software > TAC > TAC XBuilder X.X.X >Options
  3. X.X.X is the version of XBuilder e.g. 5.0.3
  4. Change the "ProjectLocation" key
  • 3302
