Change the address of a UC
  • Change the address of a UC
‎2018-09-06 09:28 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:35 AM
Can I change the address of a UC?
  • HHC
  • UCI
  • 7410
  • HC7410
Setting the address of a UC is part of the initial setup.
Plug the hand-held console into the LAN A or LAN B Communications port of a unitary controller. A black coiled cord six feet in length is used to make the connection (P/N 606014-0001; tagged: Console-1). You must sever (unplug) communications between the UCI and UC before plugging the HC7410 at this location. One end of the cord is plugged into the port on the HC7410 while the other end is plugged into the appropriate port of the individual UC.
  1. Press [DCU ADDR]. The HC7410 displays the address in positions five and six.
  2. Enter a replacement address. The address displays in positions five and six.
  3. Press [ENTER]. The HC7410 displays UC. Refer to TCON 073 or TCON 069 (UC Installation) for more details.
  • TAC INET
  • 971
