Change the IP address of a server after having added it to a PCS project
  • Change the IP address of a server after having added it to a PCS project
  • Benji
    Benji
‎2018-09-06 09:34 AM
How can I change the IP address of a server (ES or AS) after having added it to my PCS project
Project Configuration Server
You can't change the IP address of a server in the properties for that server
1. Click on the project
2. Click on "Servers"
3. Click "Properties"
4. Click on the server which IP address you wish to change
5. Change the IP address and click save
Tags (2)
  • 16643
  • communication
