Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Change of state - Dynamic values in alarm text
  • Change of state - Dynamic values in alarm text
  • sesa150561
    sesa150561
‎2018-09-06 01:04 PM
  • Dynamic values
  • Change of state
  • alarm with dynamic values
  • alarm text
  • Vista
Want a state of change alarm text to show a dynamic value
To present additional information on an alarm when it appears in the
alarms list, such as a temperature reading for a high temperature alarm,
dynamic values can be included in the alarm text.
The character @ followed by the identity of an object can be used in
alarm texts to present the value of the object (the standard property),
according to the syntax “Alarm text @object-ID “.
You may also single out a specific object property by adding a dot and
the name of the property, according to the syntax Alarm text@object-ID.mnemonic1
This function is very useful if you want to present additional text with,
for example, the description or a measurement unit of an object in the
alarm text.
Note: Priority "Info" will not work since this is a message priority and not a alarm priority
  • 6608
