Change ASC switch settings remotely
  • Change ASC switch settings remotely
‎2018-09-06 03:27 PM
Can not physically reach the ASC but the switch settings need to be changed.
  • I/NET Seven
  • MRs
  • ASCs
The units have been installed where they cannot be reached, or are otherwise difficult or impossible to physically reach.
The settings can be altered through I/STAT or the Host's ASC parameters Editor. The latest modification to the configuration always takes precedence.
  • TAC INET
  • 1058
