Certain door events are not being logged.
  • Certain door events are not being logged.
  • AbeMeran
    AbeMeran
‎2018-09-06 01:17 PM
Some door events are logged but not others.
CX9900
CX9702
CX9680
ACX5720
ACX5740
ACX781
Door's Send Access Events not configured to send events
In the door's Options tab, make sure the door is configured to send the event type in question.
If the box is already checked, uncheck it and click on apply then check it and apply a second time, this will ensure that the controller door object is in sync with the door object in the SQL database.
  • 6201
