Cannot set proper IP address in the BACnet_IP configuration screen of the WorkPlace Tech Tool software.
  • Cannot set proper IP address in the BACnet_IP configuration screen of the WorkPlace Tech Tool software.
  • sesa116868
    sesa116868
‎2018-09-11 04:28 AM
The selection list only shows the IP address of 127.0.0.1 instead of the IP Address(es) assigned in the computer's network configuration, as shown in the following screen capture.  How do I assign / select the proper IP address?
WorkPlace Tech Tool software release 5.7.x or later.
Invalid computer name.
According to the information displayed by running "IPConfig /all", the computer's "Host Name" is "localhost", as show in the following image.  This name is a reserved name that cannot be used as a  computer host name.
Change the computer Host Name from "localhost" to any other valid unique Host Name.
  • TAC IA Series
  • 13822
