Cannot see NPR across a wide area network
  • Cannot see NPR across a wide area network
‎2018-09-06 11:44 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:35 AM
Cannot see an NPR across a wide area network (WAN)
TAC INET
  • NetPlus Router (NPR)
  • Wide Area Network (WAN)
There are several reasons why this may occur:
  1. The Cisco/3Com/etc. routers are doing network address translation (NAT)
  2. The network uses Variable Length Subnet Masking (VLSM) and the routers use Classless Inter-Domain Routing (CIDR). See the other FAQ on this.
  3. The correct reference host is not specified in the configuration profile.
  4. The correct reference host is specified, but that profile was not set to active.
  5. The wrong subnet mask was used.
For issues with VLSM and CIDR (Cause 2 above), see Can NPR 2000s be installed on a network that implements VLSM and CIDR. In any other case, see Customer Advisory 2003.
  • TAC INET
  • 1247
