Cannot get the serial communications in the Pocket IA software to work on an HP IPAQ H1945 (or other similar Pocket PC devices).
  • Cannot get the serial communications in the Pocket IA software to work on an HP IPAQ H1945 (or other similar Pocket PC device...
  • sesa119747
    sesa119747
  • sesa116868
    sesa116868
‎2018-09-06 02:50 PM
  • Pocket IA software
  • HP IPAQ H1945
Some Pocket-PC devices do not support a serial interface regardless of the availability of a serial cable that is plug compatible with the Pocket-PC device.
The following procedure can be used to determine if the Pocket-PC device supports a serial interface.
  1. On the PDA, from the Start menu, select ActiveSync
  2. From the Tools menu (in ActiveSync), select Options
  3. On the displayed "PC Synchronization" screen, select the "Options" button.
  4. On the "PC Synchronization Options" screen displayed, you should see a checkbox with the description "Enable PC Sync using this connection:" with a pull-down selection box immediately below it. Click on the down-arrow at the right end of that box. If the list in the box shows only "`BlueToothActiveSync" and "`USB", the device does not support serial communications and therefore is not usable with the Pocket IA software.
  • TAC IA Series
  • 2951
