Cannot enter a "." (period) into an Object Name of an application drawing using WorkPlace Tech 5.7.4 and newer.
  • Cannot enter a "." (period) into an Object Name of an application drawing using WorkPlace Tech 5.7.4 and newer.
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 02:06 PM
Cannot enter a "." (period) into an Object Name of an application drawing using WorkPlace Tech 5.7.4 and newer.  It was possible with previous versions. Has this ability been removed?
The change to not allow a period in an Object Name was to make WorkPlace Tech compatible with StruxureWare.
If a period must be use in an Object Name, do the following:
  1. Open Notepad.
  2. Type the desired name (including period).
  3. Copy and paste it into the object's name.
  • TAC IA Series
  • 4683
