Cannot communicate with the device. (Subsystem: NS, #26)
  • Cannot communicate with the device. (Subsystem: NS, #26)
‎2018-09-07 03:32 AM
Attempting to commission a controller in an LNS environment results in the following error:
LonMaker, NL220
An NS, #26 error indicates a complete failure to communicate.  Most often this will be the result of physical layer problems.  In some situations it maybe due to a failed controller.
Check the obvious physical layer connections:
  1. Is the cable plugged into the laptop to connect to FT-10?
  2. Is the router between the computer and device being commissioned online and communicating?
  3. Are the wires terminated properly at the controller?
  4. Is the controller powered?
  5. Are there end of line terminators fitted?
Inspect the controller:
  1. Are the LEDs blinking as designed?
  2. Are you able to receive a service pin from the device?
  3. Does an MOT or NXE need to be reloaded to the device?
Typical troubleshooting techniques will usually resolve an NS, #26 error once it is understood to be a complete lack of communication at the physical layer.
  • 4105
