Cannot add the ReportService to the Services container of a Niagara G3 ENC.
  • Cannot add the ReportService to the Services container of a Niagara G3 ENC.
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 12:38 PM
The Platform Software Manager indicates the Report module is installed on the ENC, but ReportService cannot be added to the Services container of an ENC.
The following error message is displayed in the Program Director window:
WARNING [22:25:05 12-Jan-12 CST][sys.xml] Type "report:ReportService" not found: null [3:55]
javax.baja.xml.XException: Error parsing value [4:4]
at javax.baja.io.BogDecoder.err(BogDecoder.java)
at javax.baja.io.BogDecoder.decode(BogDecoder.java)
at javax.baja.sync.AddOp.decode(AddOp.java)
at javax.baja.sync.SyncBuffer.decode(SyncBuffer.java)
at com.tridium.fox.sys.broker.BBrokerChannel.syncToMaster(BBrokerChannel.java)
at com.tridium.fox.sys.broker.BBrokerChannel.circuitOpened(BBrokerChannel.java)
at com.tridium.fox.sys.BFoxConnection.circuitOpened(BFoxConnection.java)
at com.tridium.fox.session.SessionCircuits$ServiceThread.run(SessionCircuits.java)
at java.lang.Thread.run(Thread.java:823)
Niagara G3 all versions, ENC-410, ENC-520
The ReportService Module in the ENC Platform may have become corrupted.
Uninstall and reinstall the module in the ENC, making sure the module content filter is set to ui+runtime.
  • TAC IA Series
  • 7382
