Cannot access the 'Generate Authentication URL' webpage in PME2020
  • Cannot access the 'Generate Authentication URL' webpage in PME2020
  • DavidChild
    DavidChild
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2021-02-11 08:13 AM
The address used to access the Generate Authentication URL up to and including PME 9.0 no longer works.
  • EcoStruxure Energy Expert (formerly Power Manager)
  • EcoStruxure Power Monitoring Expert
Up to and including PME 9.0 the following address could always be used to access the 'Generate Authentication URL' page which allows a user to manually create urls/hyperlinks for specific PME pages (with and without authentication) to use in EBO:
http://<yourservername>/SystemDataService/Auth/GenerateAuthURL .
However with the advent of PME2020 this address is no longer valid.
The address for the 'Generate Authentication URL' page has changed in PME2020 and permission to access this new address must also be activated via a Query run on the SQL database of the PME2020 install.
Page 1676 of the PME 2020 System Guide  - Manual integration steps without using the Integration Utility - shows the required steps and the new address to be used.
Tags (2)
  • DavidKendrick21
  • DavidKendrick23
