Can web browser access be disabled in a UNC station?
  • Can web browser access be disabled in a UNC station?
  • sesa116868
    sesa116868
‎2018-09-06 12:24 PM
Customer site security requirements do not permit web browser access via the http protocol to any device on their Ethernet network so they need to be able to disable it.
UNC-410 or UNC-520
Government / corporate IT security regulations do not permit web browser access via the http protocol to any device on the Ethernet network.
If creating a new station, do not select the "Web User Interface Service" in the Add Services dialog.
If the station has already been created and is running, open the station in WorkPlace Pro and cut the "WebUiService" out of the Services container.  After cutting out the service, you need to restart the UNC.
If the WebUiService does not exist in the station, an http 400 error, "No Browser Support" error will be returned when an attempt is made to access the UNC station graphics via the browser.
  • TAC IA Series
  • 7846
