Can the manual override switches on the I/O modules still be used if the device is broken?
  • Can the manual override switches on the I/O modules still be used if the device is broken?
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 09:34 AM
We want to be able to control the outputs on an I/O even if the I/O module is broken.
StruxureWare Building Operation
I/O Modules
The switches for manual override on the I/O modules needs power to be able to operate.
The switches on the I/O modules that are used for manual override internally controls relays, that need to be powered to be able to operate.
  • 16186
