Can the latest version of the programLib jar file be used with older versions of I/A Series R2?
  • Can the latest version of the programLib jar file be used with older versions of I/A Series R2?
  • WaynePeters
    WaynePeters
‎2018-09-10 01:30 AM
The application requires use of an object that only exists in newer versions of the programLib jar file.
I/A Series R2 (all versions)
Requires use of objects only available in newer versions of the programLib jar file.
There have been no schema changes to the programLib jar file that allows the jar to be installed and used with previous versions of I/A Series R2.  Download and install the latest programLib jar file version from The Exchange Download Center.
  • TAC IA Series
  • 5553
