Can the XIF be generated for an AS?
  • Can the XIF be generated for an AS?
‎2018-09-11 12:12 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:11 AM
Automation Server
Want to add AS into another system and need XIF
In version 1.4.0 and below the Automation Server can not be integrated into other systems using LonWorks.
From version 1.4.1 and up, you can configure an "Externally Managed LonWorks Network" to the Automation Server, and as a result use the Automation Server in e.g. LonMaker or NL220. The Automation Server supports "Upload from device", but if you need the xif file, you can refer to the following guides available on the Community.
  • Generate XIF file from SmartStruxure AS - LonMaker
  • Generate XIF file from SmartStruxure AS - NL220.
Tags (4)
  • 11986
  • export
  • PeterLarsen22
  • RobertAndriolo19
