Can the LON card for MULTICAL 601/602 be mounted on an older MULTICAL 66 type?
  • Can the LON card for MULTICAL 601/602 be mounted on an older MULTICAL 66 type?
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 09:33 AM
On a MULTICAL 66, the Lon card is broken and needs to be replaced.
Does the MALON BASE card fit the older heat meters?
MELON BASE
MULTICAL
Unfortunately the LON card we have today for the newer MULTICAL 601/602 will not function with the old MULTICAL 66 meter types.
Please contact local Kamstrup Service channel.
  • Field Devices
  • 16284
