Can the DCM daughterboard be removed from a MicroSmart controller?
  • Can the DCM daughterboard be removed from a MicroSmart controller?
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 09:30 AM
After troubleshooting a communications issue, the DCM daughterboard (or piggyback board) was deemed defective.  Can it be removed and replaced with another in the field?
DMS MicroSmart controller (revision 9) -- Model numbers affected are DCM-UC, DCM-IOC, DCM-GPC
Internal board failure
Yes, the DCM board can be swapped out.  Care must be taken not to damage the pins and clips (identified below in yellow).
  • TAC IA Series
  • 16655
