Can the ASD driver of the I/A Series UNC or ENC be connected to the ASD bus actively operating under a GCM?
  • Can the ASD driver of the I/A Series UNC or ENC be connected to the ASD bus actively operating under a GCM?
  • WaynePeters
    WaynePeters
‎2018-09-06 10:59 AM
I/A Series R2 and G3 ASD driver
Attempting to directly communicate to the ASD devices with two different systems simultaneously.
The I/A Series UNC / ENC acts as the master of the ASD bus replacing the communications function of a GCM.  Do not connect the GCM's ASD bus with the UNC / ENC's ASD bus.  Connection of both devices to the same ASD bus will cause severe communications conflicts and improper bus operation.
  • TAC IA Series
  • 11475
