Can not select X Driver option on a bCX controller even though it is X Driver Enabled.
  • Can not select X Driver option on a bCX controller even though it is X Driver Enabled.
  • Dave_Shore
    Dave_Shore
  • PaulFr
    PaulFr
‎2018-09-06 02:10 PM
When editing a bCX controller Comm port you can not select X Driver option on a bCX controller even though it is X Driver Enabled.
The Drop down box for Comm1 only has Autoset and Printer options.
bCX1 Controllers, X Drivers, X-Drivers, XDrivers
When the bCX1 was first released as supported by V1.70 Cyberstation it did not support X Drivers.
  1. Cyberstation V1.70 and above support all bCX1 controllers (bCX1 9640, 4040 & 4000).
  2. The bCX1-CR (4040) did not initially support X Drivers, this feature was added in Cyberstation V1.82 and required a minimum firmware in the bCX1-CR (4040) of V4.500047 (see Compatibility Matrix).
  3. The bCX1-CR-INF (9640) did not initially support X Drivers, this feature was added in Cyberstation V1.73 and  required a minimum firmware in the bCX1-CR-INF (9640) of V1.1
  4. The bCX1-R (4000) do not support X Drivers in any version.
  • 4540
