Can modem settings be changed by dialing in to its present configuration?
  • Can modem settings be changed by dialing in to its present configuration?
‎2018-09-06 11:30 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:35 AM
A modem is already connected to a remote site's tap. Settings in the modem need to be changed. Can this be done by dialing into the modem in its present configuration?
TAC INET
I/NET remote site communicating via dialup modem
The remote site's modem needs to be connected to a PC or Laptop.
No, a modem can not be configured by using its present configurations. Windows HyperTerminal is suggested to edit modem settings.
Refer to TCON 226 (Dial Applications) and TCON 101 (Taps and Repeaters). For emulated tap set up, refer to the appropriate Controller TCON.
  • TAC INET
  • 1161
