Can individual window contacts be used in a Master-Slave configuration of Xenta 121?
  • Can individual window contacts be used in a Master-Slave configuration of Xenta 121?
  • sesa150555
    sesa150555
‎2018-09-06 11:03 AM
Xenta 121-FC
Xenta 121 -HP
Want to use Master-Slave functionally but still use each controllers window contact to control that controller.
In general exception modes are not allowed for slaves because this overrides the Master-Slave functionality. Also there are no way to prevent the master to turn on/off all slaves using it's own Window contact.
  • 11288
