Can convert an ACP file to an MS Access file (MDB) (I/NET 2000)
  • Can convert an ACP file to an MS Access file (MDB) (I/NET 2000)
  • sesa139513
    sesa139513
‎2018-09-06 03:23 PM
Can convert an ACP file to an MS Access file (MDB)?
I/NET 2000
If you are running Inet 2.xx, you have a tool to do this conversion. If you go into windows explorer\programs\Inet 2000\access-conversion editor you will see that there is a process for this. This process will allow an ACP file to convert the MDB and back to ACP files. One essential thing, if you convert the ACP file to an MDB file. DO NOT CHANGE the file structure, if you plan to convert it back to an ACP file.
  • TAC INET
  • 1262
