Can an IOU bus be wired in a Star topology
  • Can an IOU bus be wired in a Star topology
‎2018-09-07 06:13 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:35 AM
Netcontroller 1
Netcontroller 2
IOU
Wiring
CyberStation
What are the wiring guidelines for the IOU bus
An IOU bus can only be wired in a Star topology if you are using the FTT models of controller and IOUs.  See the section on the IOU reference guide starting on page 10 at the below link.
Andover Continuum I/O System Reference
  • 4469
