Can all the RAM be used in a MNL controller?
  • Can all the RAM be used in a MNL controller?
‎2018-09-06 02:59 PM
MNL controller
After doing a compile in WorkPlace Tech, there are only 8 bytes left in the RAM available (shown in the Application Statistics window).  Is there a concern if the application uses all available RAM?
The controllers are designed to operate whether there is leftover application RAM or not.  Use the WorkPlace Tech Tool 4.0 Engineering Guide (F-27254) to see the RAM memory requirements for each object.
  • TAC IA Series
  • 2563
