Can a second space sensor be added to the Micronet 2000 MN-FLO or MN-FLO3T controller?
  • Can a second space sensor be added to the Micronet 2000 MN-FLO or MN-FLO3T controller?
  • sesa119747
    sesa119747
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 02:34 PM
  • MicroNet 2000 MN-FLO / MN-FLO3T controller
  • MN-S
  • MN-SO
  • MN-SDK
Two MicroNet Sensors to one MicroNet Controller won’t function if the second MicroNet sensors address is not set to 2.
Yes. The MN-FLO and MN-FLO3T supports 2 MN-S / MN-SO / MN-SDK sensors connected simultaneously. Ensure the second sensor added is addressed as "2". The sensors come from the factory addressed as "1". To change the address, simply cut the Trace Foil. The sensor that is address 2 will only function as a temperature indicator.
Review the MN-S/MN-SO/MN-SDK General Instructions Guide (F-25715), page 7 Figure 8.
  • TAC IA Series
  • 3599
