Can a schedule in a bCX1-CR be changed by another BACnet/IP Workstation such as Citec SCADA?
  • Can a schedule in a bCX1-CR be changed by another BACnet/IP Workstation such as Citec SCADA?
‎2018-09-10 05:20 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:35 AM
Need to be able to change any schedule inside a bCX1-CR from another BacNet/IP workstation like Citec SCADA.
BACnet
bCX1-CR
Citec SCADA
It is a project requirement to change schedules in a bCX-CR1 from a third party BACnet workstation. Is this possible?
The answer to your question is not a simple yes/no. Please see page 8 of Product Implementation Conformance Statement bCX1-CR
It describes the "writable" properties of the schedule objects in the bCX1-CR v4.5.
Make sure that the BACnet workstation (B-OWS) that you wish to use to edit schedules in the bCX1-CR v4.5 supports (in its PICS) the properties that your customer needs to be able to edit.
For example, from the linked PICS, it appears the Next_Transition_Time is not writable in the bCX1-CR v4.5. If this is a property that your customer requires the Citec SCADA to edit in the bCX1-CR v4.5 then there may be a problem.
Since we do not provide support for Citec SCADA we cannot say whether or not it will work. You will need to talk to Citec or make a judgment based on their PICS.
  • 6681
