Can a UNC-520 replace a failed MSC-NC?
  • Can a UNC-520 replace a failed MSC-NC?
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 09:51 AM
Existing site with a MSC-NC and several MicroSmart controllers no longer communicates.   The user cannot view real-time data.  The MSC-NC is proven defective.  Can a UNC-520 be used in place of the MSC-NC?  There are two, separate MicroSmart trunks connected to the MSC-NC.
DMS
Niagara R2
Product failure and obsolescence
Remove the MSC-NC and replace it with the UNC-520 running a station with two MicroSmart Services - one per physical controller trunk.
  • TAC IA Series
  • 15063
