Can a Niagara R2 station be started from a command prompt?
  • Can a Niagara R2 station be started from a command prompt?
  • sesa119747
    sesa119747
  • sesa116877
    sesa116877
‎2018-09-06 02:53 PM
Niagara R2
Another option to start Niagara R2 station.
Add the Niagara bin folder to the computer path or change directories to be in that folder. Then run "station ". The command window can be minimized, but closing it will stop the station.
When the station is started in this method, it will not show "running" in the admin tool.
An example of a batch file to start station "Lon522" is shown below:
C:\cd\Niagara\r2.301.522\nre\bin station Lon522
  • TAC IA Series
  • 2839
