Can TankNet be used on the CX9680?
  • Can TankNet be used on the CX9680?
‎2018-09-10 11:35 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:35 AM
Customer wishes to upgrade an existing controller to a CX9680. The existing controller has TankNet.
TankNet
CX9680
Are there any drivers available to connect a Tanknet system to the CX9680?
TankNet is not available on any of the CX9680 comm ports. There is no driver to connect a TankNet system to it either.
A controller with the TankNet option built into the comm port must be purchased.
For leak detection applications there in an Xdriver for several Veeder-Root models. Here is a link to the Xdriver on The Exchange Download Center: Veeder-Root TSL 300 350 350R
  • 8289
