Can OPRIF 11.6 run in a full-screen on Windows 7?
  • Can OPRIF 11.6 run in a full-screen on Windows 7?
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-10 03:20 AM
OPRIF 11.6 runs in a Command Prompt window and does not maximize to a full-screen.  This is observed on a Windows 7 computer.
OPRIF 11.6
Windows 7 (any version)
By design
The Command Prompt window does not work in full-screen mode in Windows 7 as designed by Microsoft.
OPRIF 11.6 was designed to work within a command prompt window.  As a result, it cannot operate in full-screen mode.
By accessing the Properties of the command prompt window, it can be enlarged slightly:
The Magnifier program which comes with Windows 7 can also be used to enlarge the command prompt window running OPRIF 11.6.  Screen resolution will be somewhat compromised.
  • TAC IA Series
  • 6376
