Can NPR 2000s be installed on a token ring network
  • Can NPR 2000s be installed on a token ring network
  • sesa139513
    sesa139513
‎2018-09-06 03:20 PM
I/NET site
Can NPR 2000s be installed on a token ring network?
NO - Although INET hosts may work, NPR 2000s only have Ethernet NIC cards in them. Even then, token ring networks are not officially supported for the hosts.
  • TAC INET
  • 1376
