Can MN View run on Windows 2003 Server?
  • Can MN View run on Windows 2003 Server?
‎2018-09-06 02:42 PM
  • MNView
  • Windows 2003 Server
MNView has not been tested on Windows 2003 Server, the 'latest' software being XP.
If you attempt it you may find that the software is loaded to a different drive label other than 'C'. If this is the case then it will definitely not work, it MUST be loaded to drive 'C'.
  • Satchwell MicroNet
  • 3276
This is a heading
