Can Lon Tunneling be used with the Lon Flow Balance Tool?
  • Can Lon Tunneling be used with the Lon Flow Balance Tool?
  • sesa116873_brid
    sesa116873_brid
  • sesa116868
    sesa116868
‎2018-09-06 01:55 PM
Using Lon Tunnel with Lon Flow Balance Tool
Lon Flow Balance (MNL-FLOW-BAL) all versions
R2 Niagara Lon Tunnel Client
G3 Niagara Lon Tunnel Client
No, the Lon Tunnel Application (Niagara Application Tunneling) is not compatible with the Lon Flow Balance Tool.  A direct connection (PCMCIA card or USB Lon Adaptor) must be present between the Lon VAV controller and the Lon Flow Balance Application.  Also, LON1 is the only adapter address supported.
  • TAC IA Series
  • 5001
This is a heading
