Can I purchase a replacement battery for part number E17-140?
  • Can I purchase a replacement battery for part number E17-140?
  • WaynePeters
    WaynePeters
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-10 12:46 AM
DMS 35, DMS 350A, DMS 3500, DCM, MSC-MPC
E17-140 battery is obsolete and no longer available for purchase.
Purchase replacement battery E17-131.
The E17-131 battery is specified for use with the DMS-35, 350, 3500, and DCM.  This battery may also be marked N100-5058.   The E17-140 battery is specified for use with the MSC-MPC and may be marked N100-5074.    Both batteries are rechargeable Nicads.  The E17-131 battery has a slightly larger mAh capacity and a wider temperature operating range.  The E17-131 battery can be used in in place of the E17-140.
UPDATE MARCH 2016:  The E17-131 is no longer available for purchase.  Try this supplier:  www.tnrtechnical.com
  • TAC IA Series
  • 5858
