Can I have more than one version of I/Net 2000 on the same hard drive?
  • Can I have more than one version of I/Net 2000 on the same hard drive?
  • sesa139513
    sesa139513
‎2018-09-06 03:22 PM
I/NET 2000
Yes, although we do not recommend that you do this, it is possible. You will need to first partition your hard drive. After you have created two partitions, you will need to install a version of windows on each partition. One of the partitions will have to be WinNT with NT being installed first. This way you can have I/Net 1.20 on C:\ and I/Net 2.10 on D:\. The two versions of I/Net 200 cannot share a Windows registry.
  • TAC INET
  • 1297
